Ollie54
Dec 08, 2021Initiate
EX7700 as a access point
Hello, i planned to buy an EX7700. I want to use it as an access point. I want to connect it to my r7500 netgear router by one Ethernet cable and use the other Ethernet connector to connect to my ...
Dec 08, 2021Guru - Experienced User
You can connect an EX7700 to your current router and run it in access point mode. You can also connect your wired devices to it.
It'd work pretty well. A good choice in setup.
Its expected for wifi speeds to be faster by the router and drop off with distance. Thats basically how wifi works. Adding in an access point can help with that.
