dsws67's avatar
dsws67
Initiate
Jan 08, 2024
EX7700 can't set admin password after factory reset
Hi community, I needed to do the hard reset on my Extender EX7700. After reset I could connect via WPS to my Nighthawk R700 router and also a firmware update was done to v1.0.0.226. After accessing...
  • dsws67's avatar
    dsws67
    Jan 10, 2024
    I got the solution which is a bit weired.
    The problem was that I used non-english letters in the answers of the security questions. If you use e.g. this letter "ä" the admin-account-creation is not working. If you use "a" everything is fine.
