PhillH34
Dec 31, 2022Initiate
EX7700 changing Wi-Fi
I have recently changed internet provider and I’m trying to move my EX7700 to the new router. I have input the new router details in the Wi-Fi setting on the app. But the app keeps directing me to a...
- Dec 31, 2022
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Dec 31, 2022Guru - Experienced User
PhillH34
Thank you.
The link you sent have helped me find a solution.
