x4253
Nov 02, 2020Tutor
EX7700 Connection Drop and rebooting
So.. I have been using the EX7700 for a while now. My Setup: Xiaomi AX3600 as main AP (ground floor) 2x EX7700 as extenders (one in the basement and one in the 1st floor) The signal from the ...
- Nov 02, 2020
try downgrading to the 1.0.0.206 firmware, factory reset and reinstall them. disable auto updates.
I've seen a few on here with issues on the .210 firmware.
Nov 02, 2020Guru - Experienced User
Which version of the firmware are you on?
do they stay stable if only 1 of them is running?
Are they running in mesh mode?
reason I ask is in mesh mode, they connect back to the primary router's ssid. If the routers ssid drops/fluctuates, they can end up connecting to each other and not back to the router. It causes instabilities and issues. Its why I usually recommend a full mesh system like orbi if people are needing more than 1 extender.
If its stable running with only 1 unit, it could be that. Its an easy fix, you simply disable mesh on 1 device and run it with its own ssid so they don't end up connecting to each other
x4253
Nov 02, 2020Tutor
Thanks for the Answer.
Firmware is 1.0.0.210
Since last week I only run one of them as repeater, same issue as when I run 2 of them, or when i run 1 of them connected via Cat6 and run one as repeater.
