Khilkani
Jul 02, 2019Guide
EX7700 connection problems
Every now and then, my EX7700 loses the connection to my R7000 router (router connection LED vanishes). This is not the main problem. The problem is, that the extender does not try to re-establish th...
Sonjire
Jul 29, 2020Aspirant
Hello. I bought the Ex7700 last week. Actually I have a lot of disconnections. At a bout every half an hour for 5 Minutes. I already tried everything but nothing helps. The Extender is connected to my r7000 router. Is there already a solution for this Problems?
Thanks!
Thanks!
wafubloke
Jul 29, 2020Guide
No, it's shocking. I got rid of mine and went for a Ubiquity UDM and a couple of access points, not looked back.
