debrajoy
Jun 05, 2020Aspirant
EX7700 ext. connection light not amber but not white either and connection seems good
Had to restart extended because al of a sudden my iphone would not connect. My laptop and husbands phone was connected but not mine. After starting and restarting the phones network settings I used t...
- Jun 09, 2020
Maybe there's something in the floor causing blockages. try moving the extender around. things like foil line insulation, hvac, metal, can call cause signal blockaged. even tile can block signals. So sometimes a lateral move can help a lot.
Jun 05, 2020Guru - Experienced User
debrajoy wrote:Had to restart extended because al of a sudden my iphone would not connect. My laptop and husbands phone was connected but not mine. After starting and restarting the phones network settings I used the Nighthawk app and restarted the extender. Now everything is connected but the connection light is not amber but not quite white either.
Which connection light? There's multiple on the ex7700.
router link led?
client link led?
are you having an issue with it since you rebooted it?
- debrajoyJun 06, 2020Aspirant
It is the routter light. The router is a netgear router modem combo.
- plemansJun 08, 2020Guru - Experienced User
• Solid white. Best connection.
• Solid amber. Good connection.
• Solid red. Poor connection.
• Off. No connection.- debrajoyJun 08, 2020Aspirant
The Router/Modem Combo is a netgear nighthawk mesh AC1900 so it is good. So what you are saying is that good is the best I am going to get? The Router is upstairs, and the extender is downstairs, almost directly above. I restarted both of them and light hasn't changed.
But like I said light didn't change but my connection seems good. My provider is Spectrum and they had to give an activation number for the Router/Modem because it wasn't theirs.
