Griggsy
Apr 04, 2020Aspirant
EX7700 Fastlane option not available?
I just purchased the EX7700 and when setting it up I noticed that in the menu I don't have the option to use FastLane connect. Is there something I am missing here?
Apr 04, 2020Guru - Experienced User
How did you setup it up?
wps/installation wizard?
Something to keep in mind is that the EX7700 is a tri-band. If you're setting it up in extender mode, it reserves one of the 5ghz bands just for router---extender communication. its called fastlane 3 and works to reduce the throughput loss from using extenders.
- GriggsyApr 05, 2020Aspirant
I used the installation wizard as the WPS didn't seem to work.
I was referring to the below links that indicates under the 'Do more' menu option there is a way to select 'Fastlane' option. However this option does not appear on the menu.https://nighthawkmywifiext.net/netgear-nighthawk-x6-setup-netgear-ex7700/
https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it
- plemansApr 05, 2020Guru - Experienced User
Griggsy wrote:I used the installation wizard as the WPS didn't seem to work.
If you look at the fastlane article, thats for fastlane 2 devices. The article doesn't have the fastlane 3 devices (tri-bands) listed as applicable because they fastlane 3 devices function slightly differently.
- sl12svlApr 18, 2020Initiate
I am experiencing the same thing as everyone else. This was not a problem a month ago, but it is no longer available. Has Netgear advised?
