IslandEd
Sep 15, 2020Initiate
EX7700 firmware 1.0.0.210 FAIL
Just tried updating the firmware using the so called fancy app and now the extender is bricked, screwed, messed up, f@cked up! All I get is a fancy flashing green light. I've tried manually flashing ...
- Sep 16, 2020
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Sep 16, 2020Guru - Experienced User
