DavidRC
Sep 07, 2020Apprentice
EX7700 Firmware 210
Since my extender updated its firmware to 210, I have had authentication problems on the 5GHz band with my Android phone (Nokia 8.1) and tablet (Samsung Tab S6 lite). Switching off randomised MAC on t...
- Feb 09, 2021
The new firmware 216 seems to be working fine so far:
https://kb.netgear.com/000062873/EX7700-Firmware-Version-1-0-0-216
rockching80
Sep 23, 2020Aspirant
Same problem with iPhone & MacBook Pro with firmware 210. But haven't tried rolling back to 206.
- DavidRCSep 23, 2020Apprentice
I have just (an hour ago) gone back to the .210 firmware and after installing the firmware I ran Smart Setup (from the Status page). So far everything is working fine, but it has only been an hour!
That did not work as it would not connect to my Android mobile on 5GHz (IP configuration problem) so I am back on the .206 firmware and everything is fine.
- rockching80Sep 24, 2020Aspirant
Yes. I am now rolledback to 206. It looks good at the moment. I believe there is really something wrong with 210.
Just for a record with firmware 210, I also tried disable MIMO also didn't work.
