DavidRC
Sep 06, 2020Apprentice
EX7700 Firmware 210
Since my extender updated its firmware to 210, I have had authentication problems on the 5GHz band with my Android phone (Nokia 8.1) and tablet (Samsung Tab S6 lite). Switching off randomised MAC on t...
- Feb 09, 2021
The new firmware 216 seems to be working fine so far:
https://kb.netgear.com/000062873/EX7700-Firmware-Version-1-0-0-216
rockching80
Sep 23, 2020Aspirant
Same problem with iPhone & MacBook Pro with firmware 210. But haven't tried rolling back to 206.
DavidRC
Sep 23, 2020Apprentice
I have just (an hour ago) gone back to the .210 firmware and after installing the firmware I ran Smart Setup (from the Status page). So far everything is working fine, but it has only been an hour!
- DavidRCSep 23, 2020Apprentice
That did not work as it would not connect to my Android mobile on 5GHz (IP configuration problem) so I am back on the .206 firmware and everything is fine.
- rockching80Sep 23, 2020Aspirant
Yes. I am now rolledback to 206. It looks good at the moment. I believe there is really something wrong with 210.
Just for a record with firmware 210, I also tried disable MIMO also didn't work.
- DavidRCSep 24, 2020Apprentice
Hopefully, Netgear have noticed that there is a problem and are working on a new firmware.
