haywarc77's avatar
haywarc77
Initiate
Nov 01, 2019
EX7700 Firmware Corrupt
After logging into my EX7700 it asked me to update firmware. Accepted update and after restart the 7700 had a green blinking LED which is apparently corrupted firmware.
Found a discussion on here showing how to use Windows TFTP to load new firmware to the Extender, however when executing the TFTP command I received a message that the .img file (which I downloaded from the NG site and unzipped) was unreadable.
I have downloaded both versions 202 and 188 of the firmware to check if one was corrupted but I get the same message for both. As an aside if I double click on either of those file I get a message that Windows could not mount the file and it is corrupted.
Any suggestions please?
Thanks
  • Update
    This was due to my mistake of not changing the Windows CMD line directory to Desktop before executing the TFTP command.
    After correcting this the firmware loaded to the 7700 and I have it operational again
    Apologies for original posting
1 Reply
  • Update
