wirerammer
Mar 23, 2021Aspirant
ex7700 is NOT seamless mesh
Hi, i got a r7800 as router and an ex7700 in wifi range extender mode. Tried in various ways to get those working in seamless mesh, as advised on the extender, but without success. I can't move be...
Mar 24, 2021Guru - Experienced User
the dga4132 is a modem/router combo device.
Add in the R7800 and it can cause a double nat.
Also, brick/concrete are literally 2 of the best blockers of wifi there is. The EX7700 is designed to use a 5ghz dedicated backhaul. And 5ghz is much more sensitive to materials and distance than 2.4ghz is. But 2.4ghz is much slower.
so you're caught in a bit of a problem. Your home is made from materials that block wifi to a great extent. but you need wifi everywhere. Problem is wireless backhauls might not be feasible/usable in your home. You're welcome to try using several of them but many people resort to using a full mesh system and running a hardwired backhaul like ethernet, powerline, or moca adapters.
wirerammer
Mar 24, 2021Aspirant
there is not double nat i have disabled it on dga4132 and it’s acting as a bridge. r7800 is doing all the job.
the 5ghz backhaul works as expected, signals result in maximum speed from extender status.
- wirerammerMar 24, 2021Aspirantand i add that i have granted an almost open space between the router and the extender. the “not seamless experience” (sorry i don’t have another word to sum up this) happens also in place where there is no big wifi signal drops,but just a change between the two networks.
- plemansMar 24, 2021Guru - Experienced User
Not arguing that point.
but its not just the router and extender. the actual mobile device has to do the roaming and send/recieving.
The phone/tablet uses its own set of protocols for when to roam/switch between the 2. Having the brick/concrete impacts the signal that its broadcasting and receiving so is going to throw off its roaming protocol.
there isn't a good solution when you live in a home with brick/concrete
- wirerammerMar 24, 2021Aspiranti don’t understand; it happens also where the two signals are present, one better than the other; the phone switch,and the call drops. if i get back to the wifi where i started the call the call is restored. so it’s probably something that happens when the connection goes “out” of the lan.
a wifi signal analyzer that rec the signal strenghts in various spot handle well the switch and don’t drops
