brettdorron
Apr 10, 2022Tutor
EX7700 keeps factory resetting every few weeks. Loses all settings.
I have an EX7700 that keeps factory resetting every few weeks. It serves as both wifi extender and connects my wireless and wired ethernet LANs, including my NASs, in my home office. It is 12 months...
Apr 11, 2022Guru - Experienced User
something to try is to reinstall the firmware to it and then do a factory reset yourself.
Reason why is if something is corrupt in firmware, the reinstall over-writes the firmware. If something is corrupt in the settings, the factory reset clears that. Maybe its "resetting" isn't clearing everything out.
- brettdorronApr 12, 2022Tutor
Cool. Thanks plemans,
I've factory reset a couple more times and I "did" encounter problems trying to reinstall firmware. Maybe there was a problem with the previous firmware update. Time will tell. I was able to force a firmware reinstall, eventually. For now, it is working again. I'll come back if it fails again.
Thank you.- brettdorronApr 12, 2022Tutor
Ok, it reset again overnight. I suspect it needs replacing.
- plemansApr 12, 2022Guru - Experienced User
2 more things to try.
1. downgrade the firmware a version. It could always be a bug with the firmware.
2. check the power supply (i wouldn't buy one). its a fairly standard power supply. As long as it has the exact same voltage and polarity and at least as much amp (it can have more amps), then you can use. I've seen sketchy power supplies cause issues before.
If you think its bad and you're still in warranty, you can always ask for an RMA.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
- pikavaaiApr 20, 2022Aspirant
Hi,
I have exactly the same issue.
Now, Im thinking it's loadshedding ?. Do you have loadshedding in your area ?
I almost always switch the device on manually, but it goes off mostly when the power cuts.
very annoying indeed, would be nice to know if the firmware could be updated to cope with power issues. I mean the device was not $1,99.
