Gihan
Dec 06, 2020Tutor
EX7700 mesh extender - work with 2.4GHz only router
My main router only has the 2.4GHz band. Will this extender provide 5GHz bands and maintain the FastLane if I configure to use with that? Thanks, Gihan
- Dec 06, 2020
You can set it to run off the 2.4ghz for the fastlane. Issue is the 2.4ghz is still the limiting factor. You're not going to see faster 5ghz speeds because of the bottleneck being 2.4ghz.
You'd be better off to hardwire in the EX7700 and run it in access point mode.
Dec 06, 2020Guru - Experienced User
- plemansDec 06, 2020Guru - Experienced User
Or upgrade the router before upgrading the extender.
- GihanDec 07, 2020Tutor
Thanks for the reply plemans. I got this router FoC from my ISP along with a Fiber connection. Unfortunately they don't have 5GHz option. I'll check with the wired option. Thanks again.
- schumakuDec 07, 2020Guru - Experienced User
Year 2020 and Fiber ISP with 2.4 GHz only ... somewhat hard to believe.
Either way, if establishing some network cable(s) form the router is feasible, there are much better (and less expensive) solutions available.
If you need just one wireless access point, look into Netgear's Essential Wireless Access Point models WAX204 WiFi 6/802.1ax or the WAC124 802.11ac.
If you intend to deploy multiple wireless access points, head to https://www.netgear.com/business/wifi/access-points and filter for "Mesh" - this will give you options on WAC5xx (802.11ac) and WAX6xx (WiFi 6/802.11ax) - ideally powered by a PoE resp. PoE+ switch (a non-managed can be sufficient), and set-up with Netgear Insight.
