anggafs
Dec 20, 2019Tutor
EX7700 Nighthawk Tri-Band WiFi Mesh Extender, Only Broadcast 2 Band
Hello Netgear Community! I Have 8 Devices of EX7700 Nighthawk Tri-Band WiFi Mesh Extender, and I make Mesh Connection from the main Router which also same device (EX7700). The Main Node Broadcast...
- Dec 20, 2019
The triband ex7700 uses one of the wifi bands exclusively for a wireless backhaul. These works to reduce latency and increase speeds for the other 2 bands.
If you set it up with a wired backhaul in AP mode, then you'd have usage of all 3 bands.
Dec 20, 2019Guru - Experienced User
