Nakiami
Aug 30, 2021Guide
EX7700 Nighthawk X6 Extender limited to ~54mbps
I've got the EX7700 Nighthawk X6 Tri-band WiFi Mesh Extender set up as a wifi extender connected over 5GHz to my Archer VR1600v v2 router. I can't get internet down speeds above ~54mbps. Conn...
- Aug 31, 2021
the only other thing I'd try would be trying it on a different router.
A friend/family member that you can try it on.
If it doesn't work on that, then its a hardware issue and I'd open a support case.
click on "mynetgear" at the top. from there you can register an account and the device. That'll let you check warranty/support
Aug 30, 2021Guru - Experienced User
what speed do you get if you hardwire into the extender?
did you set it up using wps or using the installation assistant?
Nakiami
Aug 30, 2021Guide
Hi, thanks for your response. I have tried setting up the extender using
- the assistant in the browser
- the nighthawk app
- WPS.
If I hardwire my computer to the extender, I get the same slow speed.
- plemansAug 30, 2021Guru - Experienced User
do you have different router you could try it on?
the 54mbps is what I'd expect from a 2.4ghz but not the 5ghz.
