ChrissiePaul
Feb 08, 2022Tutor
EX7700 not working when I connect Synology DS1621+
I have recently purchased a Synology DS1621+ and connected it to Nighthawk EX7700. It worked for one day, then the whole network kept crashing. I have tried moving the Synology and plugging it dire...
Feb 08, 2022Guru - Experienced User
What firmware is on the EX7700?
What skybox is it connected to?
What method of setup did you use for the EX7700? WPS or the installation assistant?
ChrissiePaul
Feb 08, 2022Tutor
Firmware: V1.0.0.222
SKY SR203 router
WPS.
All was working fine until we connected the DS1621+.
- plemansFeb 08, 2022Guru - Experienced User
2 things you can try.
1. downgrade the firmware a version on the extender. I've seen a few reports of issues on the .222 firmware
2. try installing the extender using the installation assistant and NOT wps. I've seen ISP supplied routers have sketchy WPS setups that cause issues.
- ChrissiePaulFeb 09, 2022Tutor
How can I downgrade the firmware? I can't find an option to revert to a previous version.
- plemansFeb 09, 2022Guru - Experienced User
You download it from the support site.
on that site you go to downloads--->+view previous versions.
download the one you want, then extract it.
then follow the manual firmware process but use the older firmware versus the newer.
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
