ITSERV1
Apr 02, 2025Aspirant
ex7700 resets on restart - via switch and admin console
any guesses? I am not even doing wireless. There is wire going in at the back and I am configuring it as a access point. Still the settings are wiped on reboot. Is this happening because of unava...
Apr 03, 2025Guru - Experienced User
Its not tied into insight. Its consumer extender.
Try reinstalling the firmware to it (in case thats corrupt) and then factory reset it yourself (in case something in the settings is corrupt). Try doing that and installing using the installation assistant.
- ITSERV1Apr 04, 2025AspirantNo same result.
After firmware update added it as a wired access point. Performed a restart from the Web page. Cam up blank with default ssid netgear_ext.
What do you think about dd wrt on such a complex hardware.
Any advice will be appreciated.- plemansApr 04, 2025Guru - Experienced User
I don't believe that ddwrt supports extenders (or that one at least)
You could try downgrading the firmware a version.
something might be bad in it (think memory). The hope is that re-writing firmware will write to a different area that isn't corrupt. If it keeps happening, you might be SOL
- ITSERV1Apr 10, 2025AspirantNope didn't work I am on the first release of firmware.
I did not get a chance to upload the new firmware via comm cable. I used the Web interface🙂
I will research on it. Thanks.
