ITSERV1
Apr 02, 2025Aspirant
ex7700 resets on restart - via switch and admin console
any guesses? I am not even doing wireless. There is wire going in at the back and I am configuring it as a access point. Still the settings are wiped on reboot. Is this happening because of unava...
ITSERV1
Apr 04, 2025Aspirant
No same result.
After firmware update added it as a wired access point. Performed a restart from the Web page. Cam up blank with default ssid netgear_ext.
What do you think about dd wrt on such a complex hardware.
Any advice will be appreciated.
Apr 04, 2025Guru - Experienced User
I don't believe that ddwrt supports extenders (or that one at least)
You could try downgrading the firmware a version.
something might be bad in it (think memory). The hope is that re-writing firmware will write to a different area that isn't corrupt. If it keeps happening, you might be SOL
- ITSERV1Apr 10, 2025AspirantNope didn't work I am on the first release of firmware.
I did not get a chance to upload the new firmware via comm cable. I used the Web interface🙂
I will research on it. Thanks.
