Moshik
Dec 24, 2021Tutor
EX7700 setup lost after powering down the system
Hi, Recently, with no fw update of any electricity unusual event, my EX7700 that I use as extender, loos its configuration and needs a wired laptop connectivity in order to setup again. All front LE...
Moshik
Dec 25, 2021Tutor
Thanks,
But still cannot understand how resetting the unit can solve my issue?
And how saving the configuration on my laptop can cause the unit to boot with my configuration?
If the unit has a flash issue after one year, Netgear should do a recall for the problematic units.
As an HW engineer, it seems that there is a faulty design/component.
nielsvds
Dec 25, 2021Luminary
What I wanted to say is make a backup of your current configuration so you can easily restore from when it happens again. So you don't have to configure it again.
Did you already tried another outlet? Other reasons faulty power adaptor, overheating, hardware failure.
Where you applying a configuration change?
- MoshikDec 26, 2021Tutor
Appreciate your help,
I didnt try another power supply, it seems that the unit is working just fine for the couple of days (I didn't power it off...).
So the Power supply seems to function OK (unless at boot there is a current peak.. that the power supply cannot deliver)
No overheating I can see (from the outside).
I really consider buying a UPS just for the unit....
I saw elswere at the forum that Netgear had an issue with their flashes...
Moshik
- plemansDec 26, 2021Guru - Experienced User
I've seen specific firmwares on some devices that had issues with loosing configuration after a reboot or a certain amount of time. Its why I asked which version you were on.
Have you tried downgrading a version or 2 to see if it was something introduced with the newer firmwares?
As soon as I noticed this issue, I connected the EX7700 to my laptop and checked for FW update.
and I made an update to the latest one 1.0.0.222.
I am not sure what was the previous version but it wasn't a big change (maybe 1.0.0.220).
And even with the newest FW, the configuration lost.
Where can I find the old FW?
Moshik
