Moshik
Dec 24, 2021Tutor
EX7700 setup lost after powering down the system
Hi, Recently, with no fw update of any electricity unusual event, my EX7700 that I use as extender, loos its configuration and needs a wired laptop connectivity in order to setup again. All front LE...
Dec 26, 2021Guru - Experienced User
You can get it from the support site. Click on "downloads", then "+view previous versions"
Cudman
Jan 09, 2022Tutor
Known issue apparently, ignored by Netgear. Bad flash ram. See this post https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX7700-Loss-of-configuration-on-reboot-soft-or-hard/m-p/2119260/ for more descriptions of same problem. Recommend replacing the device to solve problem.
