XavierM
Jun 22, 2020Aspirant
EX7700 slow
Hi I have installed my ex7700, and have slow wifi in both 5ghz and 2.4 It’s currently less than 2 meters away of my router Original speed 350Mb+ EX7700 : 40Mb Why is it slowing down 10x times my ...
Jun 23, 2020Guru - Experienced User
What router are you connecting to?
What firmware is on the extender?
Did you set it up manually or using wps?
What speeds do you get if you hardwire into the extender? (lets us test the backhaul)
- XavierMJun 27, 2020Aspirant
connected to my provider router SFR
firmware 1.0.0.206
Manual setup
i'll do the hardwire test asap
thanks
