Shadowninja
Feb 07, 2021Guide
EX7700 Virtual MAC Disappearing
Hi everyone. I'm pulling my hair out trying to figure this out and I'm hoping someone from Netgear and the community can help out. I bought an EX7700 to act as a wireless bridge for my Ethernet devi...
Shadowninja
Feb 07, 2021Guide
I'm currently using 1.0.0.210. I tried 206 about a week ago but only my windows desktop had it's virtual MAC. Extender saw other devices, although it just labeled it as unknown, but no virtual MAC assigned.
I believe it's always been happening. Usually I access my Samba server from my PC which is on the same switch. A VPN server, another Windows PC and test server 1 & 2 is on that switch as well. I first started noticing the issue once I finished configuring my Samba shares and VPN server but I couldn't access it from devices not on the switch.
I checked the settings but I don't see any options for configuring the backhaul on the router or extender. Unless you mean I should connect the extender to the router via 5ghz which is already the case. I have the router and extender connected via both 2.5 and 5 GHz.
Feb 07, 2021Guru - Experienced User
So during setup of the extender, disable the "extend 2.4ghs signal" option. it uses this as a backup for the 5ghz backhaul. But 2.4ghz is slow and sensitive to interference. If the extender is to far away and sometimes defaulting back to that, it can cause issues.
To change which 5ghz channel it uses, you change it on your primary router. The EX7700 can use either the low band or the high band channels for backhaul and it uses the other for front haul.
So if your router is on channel 36, change it to the higher 149+ channels. Or vice versa.
you might have to re-setup the extender. Again, during the setup, uncheck the "extender 2.4ghz signal.
You'd still be able to use 2.4ghz as extender if you wanted, it just wouldn't use it as a failover option if the 5ghz was having issues.
How far from the router is the extender.
