dziegele
Jan 14, 2021Tutor
EX7700 won't recognize router network password
I recently bought and set up a new EX7700 WiFi extender. I used the Netgear Nighthawk app to set it up. I set it up to have the same network name and password as my router's. However, when I'm wi...
Jimmyjive
Feb 13, 2021Aspirant
Hi, could you please let me know if you resolve this issue as it sounds like I’m having exactly the same problem.
Cheers.
Cheers.
dziegele
Feb 13, 2021Tutor
Jimmy, despite valient efforts by plemans to assist me, I never got the EX7700 to work with my Verizon router and I returned it to Amazon. It appears that the only surefire way to add an extender to the Verizon G3100 router is to get the extender made specifically for that purpose, which is the E3200. In the meantime, I'm doing without.
- plemansFeb 14, 2021Guru - Experienced User
I don't have a fios gateway but some have a self orgiaizing network option.
go to: Wireless settings--->advanced security settings-->other advanced wireless options--->self organizing network and disable it.
See if that helps.
