StuartMa
Jun 04, 2019Follower
Ex800 - Setup
Any idea how I contact support? I've spent 2 hours trying to set up my new range entender. I cant log onto mywifiext.net, I cant find the network called NETGEAR_EXT. I try to reset using the reset bu...
Christian_R
Jun 07, 2019NETGEAR Employee Retired
Hi StuartMa - You may using the link below to contact support:
https://www.netgear.com/support/default.aspx
~Christian
