e1allen
Jan 19, 2022Tutor
EX8000 – AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
I had to reboot the device and after all the lights stopped flashing only the 2.4g light remains on. I've turned it off and back on a few times and get the same results. It's less than 3 years old ...
- Jan 22, 2022
Glad you got it up and working! (and that it was something simple)
If you mark it solved, it might help the next person with this issue
e1allen
Jan 20, 2022Tutor
Not sure how to do that. Care to share how to do that please?
Jan 20, 2022Guru - Experienced User
simply plug an ethernet wire into the extender and into a laptop/pc. Disable the pc/laptops wifi so it doesn't default to that.
Then try to access the extender
- e1allenJan 20, 2022TutorI have it connected to my iMac and one additional light showing the up and down arrow.
Is there a link to show the procedure?
Sorry am new to this.
Thank you for all the help.- plemansJan 20, 2022Guru - Experienced User
try mywifiext . net
- e1allenJan 20, 2022TutorTried that didn’t work. Found the IP address and entered after connecting the computer to the extender and page says it refused the connection. I did do a factory reset to see if that whorls work. Still unable to get in.
