e1allen
Jan 19, 2022Tutor
EX8000 – AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
I had to reboot the device and after all the lights stopped flashing only the 2.4g light remains on. I've turned it off and back on a few times and get the same results. It's less than 3 years old ...
- Jan 22, 2022
Glad you got it up and working! (and that it was something simple)
If you mark it solved, it might help the next person with this issue
Jan 20, 2022Guru - Experienced User
When you factory reset, it should set the extender back to its default ip address of 192.168.1.250
Is that the address you were using to try to connect?
When you reset, did you push and hold for 7-15 seconds while powered on?
e1allen
Jan 20, 2022Tutor
I did hold the reset in for about 20 seconds. The led on the back flashed red.
As for the ip address when connected to NETGEAR_EXT, the preferences show192.168.1.128.
I tried the mywifiext . net or the ip address and the results were the same. The site couldn't be reached mywifiex t. net or 192.168.1.128 refused connection.
Again, I am on macOS.
I really do appreciate the help.
- plemansJan 21, 2022Guru - Experienced User
Have you tried a different computer and/or browser?
if devices are connecting and it gets an IP address, its functioning so its to figure out why its not letting you access it.
are you setting it up using wps after the reset? otherwise it wouldn't connect to the router and be issued and IP address
- e1allenJan 21, 2022Tutor
You have been a tremendous help in making me understand that I am not smarter than the equipment.
Turns out, the Ethernet cable I connected to the extender was not connected to the computer.
LSS, I have the extender back up and running.
I appreciate your patience and understanding. Kudos to you for helping.
ttfn
- plemansJan 22, 2022Guru - Experienced User
