gigo08
Jun 28, 2021Guide
EX8000 - stability issues
Hi all, I've got the EX8000 running firmware 1.0.1.232 connected to an Asus GTAX-11000 on ASUS WRT Merlin 386.2_6. I've got both the 2.4GHz and 5GHz range extension networks turned on. The ...
gigo08
Jun 28, 2021Guide
Thanks for the reply, plemax . The previous screenshot is how the EX8000 appears when it gets into this unstable state.
I did coincidentally do a factory reset today after my initial post in an attempt to eliminate some bogus configuration as the source of my issues. I've attached a new screenshot of the EX8000 after factory reset, before it gets into it's weird state.
I'm not sure I understand your suggestion about disabling the 2.4GHz extended network and it's connection to the backhaul. I take it you want to force traffic only through 5GHz extended --> 5GHz router. Is that correct? I can think of two scenarios this helps validate -
- Issues with 2.4GHz connections (either to router or devices) put the EX8000 in some state that breaks the 5GHz but don't break the 2.4GHz connections
- Issues with 5GHz connection to router mean that the EX8000 falls back to using the 2.4GHz connection as a backhaul instead.
Are these what you are thinking might be going on? I've had a look at the LEDs on the front when it's in this weird state. From the manual, it says the "throughput" LED would turn off if it were using 2.4GHz for the backhaul but I haven't obseved that.
I'll give it a shot (disable 2.4GHz entirely) and will see what happens. If this fixes the problem then theres some serious bug in the firmware that has it falling back to a slower band without giving any indication of it anywhere.
EDIT - no idea why my images aren't working, annoying. Attached one directly.
Jun 28, 2021Guru - Experienced User
It could also be because you're using channel 100 for the backhaul. If you're in an area with active radar, the router might be going from dfs channels to non-dfs channels and back. That can cause drops/stability issues. Its also possible during those periods that its falling back to the 2.4ghz.
Another thought is your 2.4ghz is only connecting at less than half the potential link speed. It makes me curious how far away the extender is from the router and whats between the 2? 2.4ghz tends to broadcast further and through more materials than 5ghz but it seems like your 5ghz is fairly solid.
- plemansJun 28, 2021Guru - Experienced Useroh and photos have to be approved by a moderator before they show. versus just adding them as the link as you did.
- gigo08Jun 29, 2021Guide
The majority of neighboring networks here are 2.4Ghz, so I'm assuming that interference is the main reason for the slower link speed. Even sitting in the same room as the router, I wasn't getting faster than 300Mbps link on the 2.4Ghz band and usually slower than that. I hadn't worried much about it since the 5Ghz works fine.
The distance between router and extender is around 20 to 25 feet. I'm living in a Victorian house with brick walls and heavy plaster. I've attached a simple diagram so you can see how things are positioned. The scale is only an approximation, but this is roughly how it's all laid out.
I tried a bunch of different channels + setting on the router yesterday, both on the 2.4Ghz and the two 5Ghz bands but I couldn't get faster link speeds than what was already there. In the end I set everthing on the router to automatic, which I never usually do but in this case it's working fairly well.
I only bought this extender last year, but I had an older Asus router at the time. Now that I have this one which supports Wifi 6 I might replace this extender with an AiMesh satelite that handles Wifi 6 on the backhaul and just walk away. I'm hoping some configuration setting will fix this, but I've never had a piece of wireless hardware that required as much tinkering as the EX8000.
- plemansJun 29, 2021Guru - Experienced User
brick and plaster are close to 2 of the worst materials for blocking wifi.
Usually when I find people with those types of homes, I advise them to find a way to hard wire in access points/extenders.
The plaster/brick makes the wireless connection unstable and unreliable. Some can get it working but most struggle.
To hardwire it you can investigate moca adapters (ethernet over coax), powerline, or even running a few runs of ethernet (if you own the home). Sometimes the cost is offset with much better stability. Plus if its hardwired, the cheaper mesh systems (dual band mesh) can be hardwired in and function as well or better than the triband mesh systems.
But if you've got it working, great. If it stuggles with stability, I'd look into hardwired connections for your access points.
Yeah, these houses are tough for wifi. What's crazy is that my neighbors upstairs network comes through really well because there are only wooden floors and beams + a bit of ceiling plaster between us. But down the hall in my own apartment its a struggle.
Unfortunately I don't own this place, but I may try some ethernet cable run along the edges of the room and then at least get a wired backbone to the extender.
All of this (while helpful) doesn't explain the wonky state that the extender gets in though. I'm convinced that beyond whatever signal struggles there may be, the extender also gets to some point where it is not behaving. Signal interruptions are likely to be sporadic. When the extender gets to it's "unstable" state, even it's own UI barely works.
Are you aware of any way to turn on logging or other diagnotic functions in the firmware? The controls are so basic that I can't get anything beyond a status from the admin UI.
