DaveIRE
Oct 09, 2018NETGEAR Expert
EX8000 802.11k when in AP mode
I know the EX8000 supports smart roaming using the 802.11k standard, however I need to know if this only works when using the unit in extender mode or if it also applies when you are using it in AP mo...
ChrisL1971
Oct 09, 2018Guide
In AP mode i've no problem then i walk around the house.. the IP number and MAC of the client remains te same(one subnet for all AP's + router) and that is sufficient.
DaveIRE
Hey ChrisL1971,
What is the router you are roaming to and from with the EX8000? Does it also support 802.11k?
With any luck Netgear will implement 802.11v and r as well as 802.11k on the EX8000.
- ChrisL1971Oct 09, 2018Guide
My router is a R7800
- schumakuOct 09, 2018Guru - Experienced User
Wireless STA can switch in a reasonable time from one AP STA to another AP/router STA usually. For this, the advanced modes are not required - no doubts that this does basically work - without 802.11k, 802.11v and 802.11r.
However, for truly seamless roaming, especially with multiple AP STA in reach, there is no way around 802.11k Radio Resource Management (RRM) and 802.11r aka. fast BSS transition (FT) also called fast roaming. This will allow ongoing VoIP calls or video streams while changing BSS.
