ajnet1186
Jul 14, 2018Aspirant
EX8000/ AC3000 -power light flashing red
All has been fine, but this morning all lights at the front stuck flashing white, and the power light at the back flashes red. I tried disconnection power for a bit, but on plugging back in, power li...
robjpugh
Jul 15, 2018Aspirant
I have the same problem, everything ok until this morning when all the lights on the front flash and the power light flashing Red. Have you found a solution?
- ajnet1186Jul 15, 2018Aspirant
Good to know that I am not alone. No info in the manual about the led on power at the back, so netgear need to respond with solution I think.
- robjpughJul 15, 2018AspirantAfter talking with amazon support they Decided it was a software fault and has issued me a replacement my unit is only six months old. You’re totally right there is nothing in the manuals about the flashing lights Front or back.
- SevenAndrewJul 28, 2018Aspirant
Thank you all for writing the answers!
I have the same issue, since a couple of days and was looking for the answer of the red flashing power LED and the white flashing front!
I'm going to contact amazon for exchange!
Best regards!
