youngnmoon
Jul 02, 2020Aspirant
EX8000 AC3000 Tri-Band WIFI Range Extender wont work with Apple devices
Any Apple products hooked to the extender do not connec to internet. They do connect to the extender, but there is no network connection to internet. Mircosoft computers and Android devices work ...
youngnmoon
Jul 03, 2020Aspirant
1.Router model is Verizon G3100
2.Firmware is 1.0.1.202
3.I use installation assistant (mywifiext)
4.Wireless Security Type is
WPA + AES I chose 2nd option in setting in installation assistant
Jul 03, 2020Guru - Experienced User
try using WPA2-PSK
- youngnmoonJul 03, 2020Aspirant
I tried WPA2-PSK and TKIP still not working .
- plemansJul 04, 2020Guru - Experienced User
Something to try?
If you've got a friend/family member, try installing it on their system and see if the mac devices connect and work. the router is the backbone of the system. Just to ensure it isn't a router issue when using an extender.
