myamaung
Sep 24, 2020Aspirant
EX8000 all lights are blinking
Can't read, no connection at all. I turned the power off and turn back on Extender was start blink all lights and no boot up at all. Even though can't reset to factory default. Could some one explain ...
Sep 24, 2020Guru - Experienced User
to factory reset, push and hold the reset button while its powered on. Hold it for up to 30 seconds.
then let it boot up. It might take a couple minutes.
Did that work?
If not, you might have corrupt firmware. you can try recovering it via tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
