herb274
May 30, 2022Tutor
EX8000 and Frontier NVG468MQ fiber optic modem/wireless router
Can I use my Netgear EX8000 range extender with the Frontier version of the ARRIS NVG468MQ modem/wireless router? If yes,how do I connect them? Thank you, Herb
May 31, 2022Guru - Experienced User
You should be able to.
I'd simply install it using the installation assistant. Tends to be the route that works the best.
here's a video of how to use the installation assistant
