delgado
Feb 18, 2020Tutor
EX8000 (AP) 5GHz Channels 116 and above do not work anymore
Hi there, Lately I have a nasty issue with my EX8000 running as Access Point for two separate 5GHz SSID’s ... Usually the band with the 1700mbits sits on channel 100 - 112 which was working just fi...
Feb 19, 2020Guru - Experienced User
What region are you in?
what region is the extender set it?
What region are your devices in?
Reason I ask is different regions have different restrictions on DFS channels. If the region is set different from 1 device to the next, it can create issues or "unusable channels". Or even channels that are very low power for that region.
- delgadoFeb 19, 2020Tutor
its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
- plemansFeb 19, 2020Guru - Experienced User
delgado wrote:its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
I understand that you've stated that region. do you have that region setup on the EX8000? AND on your devices accessing it?
yes sure :) ... i mean, it was working for more then a year now ...
