delgado
Feb 18, 2020Tutor
EX8000 (AP) 5GHz Channels 116 and above do not work anymore
Hi there, Lately I have a nasty issue with my EX8000 running as Access Point for two separate 5GHz SSID’s ... Usually the band with the 1700mbits sits on channel 100 - 112 which was working just fi...
Feb 19, 2020Guru - Experienced User
What region are you in?
what region is the extender set it?
What region are your devices in?
Reason I ask is different regions have different restrictions on DFS channels. If the region is set different from 1 device to the next, it can create issues or "unusable channels". Or even channels that are very low power for that region.
delgado
Feb 19, 2020Tutor
its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
- plemansFeb 19, 2020Guru - Experienced User
delgado wrote:its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
I understand that you've stated that region. do you have that region setup on the EX8000? AND on your devices accessing it?
- delgadoFeb 19, 2020Tutor
yes sure :) ... i mean, it was working for more then a year now ...
Have you tried a factory reset and re-install?
Or tried re-installing the firmware? it wouldn't be the first time firmware was corrupted. A reset only removes settings, not overwrites the firmware.
