delgado
Feb 18, 2020Tutor
EX8000 (AP) 5GHz Channels 116 and above do not work anymore
Hi there, Lately I have a nasty issue with my EX8000 running as Access Point for two separate 5GHz SSID’s ... Usually the band with the 1700mbits sits on channel 100 - 112 which was working just fi...
delgado
Feb 19, 2020Tutor
its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
Feb 19, 2020Guru - Experienced User
delgado wrote:its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
I understand that you've stated that region. do you have that region setup on the EX8000? AND on your devices accessing it?
- delgadoFeb 19, 2020Tutor
yes sure :) ... i mean, it was working for more then a year now ...
- plemansFeb 19, 2020Guru - Experienced User
Have you tried a factory reset and re-install?
Or tried re-installing the firmware? it wouldn't be the first time firmware was corrupted. A reset only removes settings, not overwrites the firmware.
yes i did a full factory reset and also tried several different FW's
.202 / .192 / .118 and the current 206 of course
