lemmy999
Jul 13, 2018Guide
EX8000 backhaul options
I have a dual band R7800 (AC2600) roouter. I was considering purchasing an EX800 but had a couple of questions that I can't find the answer too.
1. I know if I had a tri band router then on...
lemmy999
Jul 17, 2018Guide
Thank you for the response.
So there is no difference in functionality (regarding smart switching between the router and the EX8000 for my devicesssss) when using the EX8000 in AP mode (same SSID and password as router) with wired backhaul to the router versus using the EX8000 as a mesh extender with wireless backahual?
arunkmony
Jul 17, 2018NETGEAR Employee Retired
Yes, it should work fine.
