colst03
Jun 13, 2022Tutor
EX8000 Broken - All leds are blinking
Dear All, I can not access to my EX 8000, . the back red power led is blinking . the front white leds are blinking. I am connected to it though a direct ethernet cable rj45 but I do not see...
colst03
Jun 14, 2022Tutor
Thanks
I did and found how to make hard reset and it did not Work but not a "recovery" reset.
I should have been more precise. For the firmware update no issue also probably but for the moment I have no Access to the device. A nice brick only. 🙂
olympos1625
Jun 15, 2022NETGEAR Employee Retired
Hi colst03,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for the inconvenience this has caused you. Please the steps from the link below if we can still recover the firmware.
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/TFTP-update-on-EX6100v2/m-p/1882014
Note: If PC or laptop doesn't recognize the extender when you hardwired it even though you set a static IP, hardware replacement would be the next thing to do. You may contact our support for this one. 1-888-638-4327.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- plemansJun 17, 2022Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
