SoCaloc's avatar
SoCaloc
EX8000 Does not appear to sustain or boost wifi
Hi,  Hope everyone is well.   I have a nighthawk r7000 router in my office and my wifi does not reach my living room - about 30-40 feet away.  I purchased the ex8000 to extend my wifi and to also assist with keeping my nest hello connected to wifi.  I set up the extender today and moved it outside of the office about 15 feet away.  I did not see any difference in wifi with or without it.  I used a wifi analyzer and I get 866 mbps speed in the office, it drops to about 500 where the extender is (15 feet away).  if I measure to my front door, another 20 feet, the link speed is 35.  If I turn off the extender, I get about the same readings 480 - 500 mbps and the door has the same measurement.  I moved the extender closer to my front door (further away from the router), about 10 feet away and I was getting poor wifi around the extender - about 35 mbps. I don't believe that this is working.  I tried calling support, and was number 80 in line, I used the chat and got through.  We did a factory reset and reconnected - same results.  the lights on the front are all white - I used a browser and connected to the extender and everything was green.  I don't know if I should just return it or if I am missing a setting or something else, anything.  all suggestions are welcome.
  • plemans's avatar
    What materials is your home interior walls made of?
    Certain materials block wifi extremely well. These include adobe, plaster lathe, brick, concrete, foil lined insultion, metal hvac
    Reason I ask is a standard wood/sheetrock home shouldn't have issues broadcasting wifi 40ft. In fact, for a system like orbi, it requires at least 30 ft between router/satellites. So 40ft shouldn't be a problem which makes me suspect the home might be the issue.
    • SoCaloc's avatar
      SoCaloc
      Hi,
      Thank you for the reply.  I live in a standard wood stud / sheetrock home build in 2000ish.
      The extender, has most of the white lights lit up (if you count the lights, there are 8 of them, numbering from 1 to 8 - left to right, all lights are solid white except lights 5,6 and 8 which are not illuminated).  I just do not see any difference in the signal strength with the extender - I don't think it is doing anything.  thanks again.
      • SoCaloc's avatar
        SoCaloc
        I just used my tape measurer and the extender is 18 ft and 3 inches from the router - a straight line.  I can see it through the doorway - which is always open.
