Ibaroj
Aug 03, 2024Tutor
EX8000 extender disassembly
I am diagnosing a dead EX8000 and cannot see how to release the bottom half of the case. Nothing found in searches. There are only two screws at the top so there must be a trick to unlatching the bott...
- Aug 11, 2024
The case is quite different from the Orbi though. But I solved my problem, with a Dremel tool lol. After a couple of days struggling I cut thru the seam. That'll show 'em!
An exploded view would have come in handy; couldn't find anything.
Ibaroj
Aug 11, 2024Tutor
Aug 12, 2024Guru - Experienced User
Lol thats one way to do it!
