resed
Mar 18, 2022Aspirant
EX8000 Green power light flashing green.
I replaced my firmware in January 2022 when instructed to do so and all was fine until 3 days ago. The unit is off line and the NETGEAR_EXT wireless link does not show up on my iMac computer or iPho...
Mar 18, 2022Guru - Experienced User
did you start with a factory reset?
Push and hold reset for up to 30 seconds while powered on.
Then give it a few minutes. I've had it take a while to fully boot.
If that doesn't work and you can't get tftp to work, you can try nmrpflash.
resed
Thank you. I had not done the full 30 second reset in advance so I have started over and retried everything, starting from scratch. I still never get to a flashing orange power light and it still tells me the EX8000-V1.0.1.240.img file does not exist, even though it is sitting on the desktop and have entered the correct information into terminal to access it.
I took a look at the nmrpflash option and I am pretty new to terminal and am not confident enough to try it. Also, you had a comment in the link that indicated what NETGEAR equipment it had worked on and the EX8000 was not listed. I guess I am stuck at this point, but thank you for the help.
