lynnkuh
Jan 31, 2021Aspirant
EX8000 keeps losing the 2.4gHZ channel Hardware Version: EX8000 Firmware Version: V1.0.1.22
I've contacted support numerous times and so far I've unplugged, reset, and factory reset it. It worked for a day with factory reset but it lost the channel after a day. Do I need a new one or is it ...
Feb 01, 2021Guru - Experienced User
when you're running your initial setup, try uncheck the "extend 2.4gh" box.
You'll still be able to use the 2.4ghz but then it forces it to use the 5ghz backhaul versus occasionally defaulting back to 2.4ghz backhaul.
2.4ghz is more sensitive to interference and much slower. So anything you can do to make sure it isn't using only the 2.4ghz from router-----extender and then extender----device.
lynnkuh
Feb 01, 2021Aspirant
There is no extend 2.4Ghz box. There is a disable 2.4Ghz radio which disables it but then only have 5Ghz available. I have devices that work only on 2.4Ghz channel.
- michaelkenwardFeb 02, 2021Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.Is the Extender in wireless repeater or wireless access point (AP) mode wired to the router?
If in repeater mode, what speed is the link to the router?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software and firmware for your device.We don't actually know very much about the problem you have. For example, you said earlier:
it lost the channel after a day.What is "it" and what "channel" are you talking about.
In other words, provide a detailed description of what is happening and what you see and you might get more detailed advice.
This helps to rule out things like issues with your wifi clients rather than the extender.
- plemansFeb 02, 2021Guru - Experienced User
lynnkuh wrote:There is no extend 2.4Ghz box. There is a disable 2.4Ghz radio which disables it but then only have 5Ghz available. I have devices that work only on 2.4Ghz channel.
When you're going through the initial setup, it asks about "extending the 2.4gh". If you uncheck it, you're still able to use 2.4ghz but it piggybacks the signal onto the 5ghz backhaul. Its only possible to do while doing the initial setup.
It normaly does piggyback the 2.4ghz onto the 5ghz with the tribands but if there's an issue with the backhaul connection, it'll use the 2.4ghz as a backup and 2.4ghz is slow and sensitive to interference.
