Past-It
Oct 02, 2022Aspirant
EX8000 mesh extender not boosting 5G
EX8000 firmware 1.0.1.240 My router outputs 2.4G & 5G. EX8000 2.4G & 5G lights are on. 2.4G booster is working fine. 5G is not. Router setup is fixed channel 48. Nighthawk shows channel 104 (DFS). I...
- Oct 05, 2022
The photos are far from good but serve their purpose. Red peak shows 5G output from router (channel numbers hidden by advert). The star photo is far from pointless. It shows the 5G router output (ch48) & also demonstrates that there is no 5G boost signal on any of the 5G channels. Installing inssider would be a waste of time as my PC is hard wired, no Wi-Fi so not helpful.
The lack of 5G boost is likely to be either a setting not correctly made (no-one has come up with a likely culprit) or a faulty Netgear extender which means an expensive replacement..
It's probably time to end this topic, thanks to those who have tried to help.
williamhoke
Oct 02, 2022Tutor
Best Wi-Fi extenders of 2022: top devices for boosting your WiFi network ; 1. Netgear Nighthawk X6S EX8000 Tri-band WiFi Extender.
- Past-ItOct 02, 2022Aspirant
Do you seriously think that your post was helpful?
- michaelkenwardOct 02, 2022Guru - Experienced User
And your reply adds .... ?
Remember, this is a user-to-user community. We are all sharing experiences and advice. There is a good chance that other people will read your subject and drop by seeking help with a similar issue.
If they are lucky, they may read the comment from williamhoke before they get too invested in a particular choice.
The rules here are to be courteous to fellow visitors. Feel free to ignore things that you see to be off piste.
