jhex7000
Mar 20, 2019Guide
EX8000 Mesh Network Installation
I started the install of the EX8000 and connected it to my routers 2.4 and 5gHz networks. All the LEDs are lit on the EX8000 excluding the USB and Ethernet lights. I logged on to the EX8000 and went ...
Mar 20, 2019Guru - Experienced User
What is the Mfr and model# of the main host router?
If your seeing only two SSIDs from the main host router, this is a dual band router. the EX8000 is a tri band Extender. The EX would only be using the two radios instead of 3.
I would rename your host wifi SSIDs to Network2 and Network5 to help lessen the confusion of SSID naming conventions.
jhex7000
Mar 22, 2019Guide
I have to contact support to hopefully get instructions on how to install the EX8000 as designed and not just as a wifi extender (which is how support set it up previously) - else it is going back.
- FURRYe38Mar 22, 2019Guru - Experienced User
The EX is a triband router and to make use of all 3 radios, I believe the main host router needs to be a tri band as well having 3 radios...
Let us know what you find out. I'm curious about this as well.
