jhex7000
Mar 20, 2019Guide
EX8000 Mesh Network Installation
I started the install of the EX8000 and connected it to my routers 2.4 and 5gHz networks. All the LEDs are lit on the EX8000 excluding the USB and Ethernet lights. I logged on to the EX8000 and went ...
jhex7000
Mar 22, 2019Guide
I have to contact support to hopefully get instructions on how to install the EX8000 as designed and not just as a wifi extender (which is how support set it up previously) - else it is going back.
Mar 22, 2019Guru - Experienced User
The EX is a triband router and to make use of all 3 radios, I believe the main host router needs to be a tri band as well having 3 radios...
Let us know what you find out. I'm curious about this as well.
