Bellon
Jan 31, 2021Tutor
EX8000 Nighthawk Range Extender won't connect to StarLink Wifi Router
I just received my StarLink home Internet kit. I've installed the unit, and hooked up all of my devices to it. I have two smart home devices that require a hardwire connection, so I decided I...
Jan 31, 2021Guru - Experienced User
Not many people with starlink. Your the first I've seen.
Are you using any special characters in your starlink ssid/password? If so, try removing them.
did you contact startlink to see if there's any special features/settings that need to be changed to connect an extender?
Again, sadly, there's not much experience with starlink or their router setup.
