Bellon
Jan 31, 2021Tutor
EX8000 Nighthawk Range Extender won't connect to StarLink Wifi Router
I just received my StarLink home Internet kit. I've installed the unit, and hooked up all of my devices to it. I have two smart home devices that require a hardwire connection, so I decided I...
Jan 31, 2021Guru - Experienced User
Not many people with starlink. Your the first I've seen.
Are you using any special characters in your starlink ssid/password? If so, try removing them.
did you contact startlink to see if there's any special features/settings that need to be changed to connect an extender?
Again, sadly, there's not much experience with starlink or their router setup.
Bellon
Feb 01, 2021Tutor
No special characters, and all of my wifi devices connected just fine.
The Starlink website indicates that the wifi is both 2.4 and 5, but doesn't have separate "names" for both.
When I first connected my PC to the wifi, it did pop up a screen indicating that the wifi had the latest security protection.
Is there an update for the nighthawk extender that I need to download to make it work?
- plemansFeb 01, 2021Guru - Experienced User
Bellon wrote:Is there an update for the nighthawk extender that I need to download to make it work?
Unknown.
As far as I know, the starlink routers are based off openwrt which works fine with the EX8000.
Are you setting it up using wps or using the installation assistant?
what firmware are you on for the EX8000
