sylvainjapan
Jul 21, 2019Guide
EX8000 not starting after firmware update (blinking white)
Hello, Today I did the update of the firmware of my extender EX8000, and after the update it's not working anymore. All the ligh are blinking white. I tried a factory reset but the result is th...
Jul 21, 2019Guru - Experienced User
you could try doing a tftp restore procedure. You can use this for extenders and routers.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Here's a thread from someone who had the same/similar issue and did a write up of how they got it to work. I'd read through how they did it for tips/tricks prior to doing yours in case you have similar issues they did.
ARH47
Nov 08, 2019Tutor
I am having the same problem, just one month after warranty expired, of course, but all I did was turn off the extender, which was working fine, then turned it back on, now all it does is blink white lights across the front. The power button LED in the back turns to blinking red after a few seconds, too. Factory reset button doesn't do anything. I do not understand what is going on with the solution the other person dougho2 found in the link. He states that his EX8000 is having this problem, then goes on to say how he did things to the "router" and reinitialized the "router". Does he actually mean the extender? Should I replace the word "router" with "extender" in his solution? I do not see how what he did with the "router" does anything at all to the extender? Please help. Thank you.
