eggs4sale
Mar 23, 2021Initiate
EX8000 Power Light Flashing Red
Decided to factory reset EX8000 while the power was on (not sure if thats good or not), since I wasnt able to access the internet even if my computer was connected to the EX8000 through ethernet. Whe...
- Mar 24, 2021
I'd first start with a factory reset. Push and hold reset for 7-15 seconds while its powered on.
If that doesn't help, then you can try recovering with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Mar 24, 2021Guru - Experienced User
eggs4sale
Mar 24, 2021Initiate
Thank you so much, I was following the youtube video first, and thought tftp2 wasnt working, didnt know you suppose to use tftp2 on cmd prompt.
