malandraeliott
Jun 11, 2018Tutor
EX8000 Serious ethernet firmware bug in V1.0.0.126
In the latest firmware (V1.0.0.126) if you connect a computer to the ethernet interface on the EX8000 and then put the computer to sleep (in this case an iMac), the 5 GHz wifi signal on the EX8000 dr...
DexterJB
Jun 12, 2018NETGEAR Moderator
Hi malandraeliott,
Welcome to the community!
1. Please make sure that a factory reset is done after the firmware update.
2. When it drops, does the signal completely disappear or does it disconnect devices connected to the 5GHz band?
3. Does the issue persist on all Ethernet ports of the extender?
Dexter
Community Team
malandraeliott
Jun 12, 2018Tutor
Thanks for picking up this thread.
1. Yes, I've tried two factory resets and no luck
2. I'm looking via a wifi analysis tool (Wifi Explorer) and I see the signal completely drop (and obviously any connected devices lose their connections)
3. Yes
I've also tried different ethernet cables, physically moving the EX8000 in case of any situational interference and altering the channels in case of any other interference. No luck.
